Aligning Y-axes of two graphs when scales are changed
This is simplified version of my problem:
  • FP is divided by a splitter
  • Each pane has single control: a XY Graph
  • Each XY Graph fits to its pane
  • Y-scale: autoscale is on
The image illustrates the problem
  • Initial state: both Y-axes are aligned (left in the image)
  • If scale values occupy same width, the axes are still aligned (center)
  • If scale values occupy different width, the axes are misaligned (right)
Please advise how I can keep Y-axes aligned when scales are programmatically changed.
I attach the test VI for convenience.
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
Message 1 of 8
(3,363 Views)
AFAIK, the Y axis width will always resize depending on the width of the marker texts.
You may use a fairly constant-size numerical format, for example:
It's rather ugly, though.
Paolo
Message 2 of 8
(3,331 Views)
Accepted by _Y_
Right-click on each graph and select Advanced, and then uncheck Auto Adjust  Scales.
This will stop the Y-scale position from moving when the scale range changes.
Message 3 of 8
(3,303 Views)
It's always time to learn something new. I just overlooked this option. I rather expected it as a property for each scale, instead of a global option.
Paolo
Message 4 of 8
(3,275 Views)
Thank you. It works but one small thing is still annoying. Axes stay in their place now but position of axis titles are changed dependently on width of numeric values. I can solve it selecting a monospaced font (f. ex. Courier) and setting minimum field width:
However, for proportional fonts this setting improves the situation only partially.
Is there any way to lock scale titles to their initial positions?
Message 5 of 8
(3,270 Views)
Maybe your expectations are too high...
I guess that whatever setting you can apply, LabVIEW would never allow the scale markers to overlap with the title. You cannot guarantee this for an arbitrary marker length. So, let enough space between the title and the scale markers.
Paolo
Message 6 of 8
(3,247 Views)
Why not use the mixed signal graph?
Greetings from Germany
Henrik
LV since v3.1
Message 7 of 8
(3,242 Views)
Thank you Henrik,
The reason is simple. The question comes from support of an existing project.
Message 8 of 8
(3,205 Views)
