Again... Graphing Problems...
Thanks to everybody that replyed last post!
I agree with you, these sequences are overkill.
But... this was just a simplified simulation. Real software is very sequentially programmed. There is no parallelism at all. One motor running at a time (due hardware restrictions)
task-> check status -> more tasks -> case... & so on...
I don't even know why we are using Labview...
Anyway... nothing has changed this way yet.
This is a more simple question... and it's pointed with red "here!" so you don't get lost.
This "Speed 1 - Copy" graph behaves kinda like it should. Updates every time a mass is moved...
But...
1) I can't initialize it. ? Constant I tryed is also pointed.
2) every parameter should have a different color.
(See Speed 1 - FWD).
Many thanks again...
[]'s
Erick
Message 1 of 9
(3,819 Views)
Ok Erick, give me a little bit of time and I'm gonna show you what I meant earlier by telling you to get things legible.
The problem you have with your copy is that there is only one color because there is a single plot. I'm gonna also try to show what I meant.
The initialisation has to be done in the first sequence of your VI.
Hope this helps ! You won't have to wait for more than 20 hours to have your new VI cooked.
Julien
Message 2 of 9
(3,819 Views)
Hi Erick,
I worked a little bit on your VI in order to show you how to update your XY Graphs in each iteration of a loop.
I made it a bit more legible, but didn't change anything in the way it worked.
I also made a subVI that simulates a new speed, freq and current.
I added differents graphs for Backward and there are really too much of them now...
I hope you'll be happy with this.
Julien
Message 3 of 9
(3,819 Views)
Many many thanks...
Only problem is we have LV 6.1... ain't running!
[]'s
Erick
Message 4 of 9
(3,819 Views)
Here are the ones that work with LV6.1
It should be allright now
Julien
Message 5 of 9
(3,819 Views)
Oh!
I can't believe the work u had and time u spent with this VI!
Sure u work for NI and your boss obligated u to help me! 🙂
Send me his email so I can tell him good things about u.
Merci...
Je suis vraiment choqué...
(I've been learning french for the last 2 minutes.. with the help of google translator)
Merci...
over and over again.
Erick
Message 6 of 9
(3,819 Views)
I'm happy that my work was what you were trying to do. I hope I didn't change the way your VI worked previously.
I'm currently doing a training period (3 months to go) in Toulouse (France) but if you've got work for me ... 🙂
Julien
Message 7 of 9
(3,819 Views)
Sorry,
U have no luck at all... you just helped a trainee (wich is the lowest ranked position ever!)
Anyway, I'm working in Dortmund until end of August ( I come from Brazil). So if u need anything or have any interest in Germany, please send me an email:
brenner@elliptec.com
Best Regards,
Erick
Message 8 of 9
(3,819 Views)
Nevermind, I'll be happy to help you again if you've got more questions.
Julien
Message 9 of 9
(3,819 Views)
