Adler-32 Checksum
(1,737 Views)
Hi MrFuppes,
have you tried to implement this yourself?
It seems pretty easy with just 2 shift registers in a loop…
(1,732 Views)
Hi GerdW,
not yet, but will do so I guess if there are no "stock" .vi available...
(1,728 Views)
Accepted by MrFuppes
Here's an implementation:
(1,648 Views)
Hi MrFuppes,
you see: really easy!
You can delete the ArraySize node, autoindexing at the loop tunnel is all you need…
(1,645 Views)
sure, & thanks. still need to get used to programming in LV 😉
(1,641 Views)
The Adler-32 solution by MrFuppes is incorrect for large data sets.  The high (B, s2) and low (A, s1) should be converted to U32 prior to the add and modulus.
Example:
"abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz"
ADLER-32: 0x09832C7D
(582 Views)
