Adding sine waves
thank you for your answer.. i will try again.:)
Message 11 of 33
(6,327 Views)
Raven covered the issue well.
The first thing to correct is the "Selector".  You cannot wire doubles.  Your Case Structure is actually expecting a String.
Another point to mention is that you could implement the math directly using Labview functions (vi's).
(EDIT: Can't believe it took me 3 hours to post the reply 😉  LOL!)
Message Edited by JoeLabView on 05-28-2008 08:06 PM
Message 12 of 33
(6,317 Views)
hi again..ı have one more question. you explained well and ı made some changes also the question is this ı know that ı should add a converter but which converter ı couldnt find:s  ı m looking forward for your answer ı hope it will be soon:)
Message 13 of 33
(6,303 Views)
ın this project and at the case structure n and wn  must be number that is the meaning of this that should be numeric(blue ) is that true? And the other ones must be variable (orange ) to solve the error I must have converter is that true? but which one I dont know.
ıf this idea is wrong how can I solve this ?
Message 14 of 33
(6,297 Views)
Before we answer your question, please explain what the cases mean..
In other words:  What does "L"..."L/2" mean?  Is it a range of values?  If it is a range of values being L to L/2, then do the math outside the case and use the In Range? function and the boolean output would select the TRUE case..
However, you have other cases in your Case Structure..  Which means that a True / False scenario would not be approprite.  I don't have LV installed on this PC, so I can't remember the other cases...
What you could do is use a Selector and if the case I just described is true, then you could select a string saying InRange.  Then change your case to the same string "InRange" instead of "L2"..."L/2".  So if it is in range, it would go to that case in the Case Statement.  This way, you can have additional cases to handle the other scenarios.
Do you understand what I described above?  It's actually easier than it sounds..  😉
RayR
Message 15 of 33
(6,286 Views)
Hi, Can u plz help me in adding 6 sine waves and it should show the addition of sinwaves as per our interest for e.x. addition of A+B or B+D or B+D+F or A+B+C+D+E+F
Message 16 of 33
(5,911 Views)
Since your problems looks like it has nothing to do with the original thread, you really should have started a new thread.
Since you are doing the same thing 6 times over, I would recommend putting your parameters into an array.  Then it is really easy to do the work in a FOR loop.  This would also allow for more or less waveforms.
Message 17 of 33
(5,888 Views)
thank you 🙂 , but i should keep frequency same(constant) for all 6 sinewaves is that possible, can u plz try in my way ?
Message 18 of 33
(5,868 Views)
Addition of six sine waves
Message 19 of 33
(5,844 Views)
You must be kidding! Are you gettting paid by the diagram size and total wire lenghts?
Message 20 of 33
(5,837 Views)
