Adding Date/time to 1d array of data saving as CSV
Why are you using Initialize Array?  I think you want that to be Number To Fractional String.
Message 11 of 14
(1,159 Views)
Hi crossrulz,
I dont know I just followed what someone has suggested. Can you let me know how to proceed with this or can you show me on my labview file the changes?
Message 12 of 14
(1,150 Views)
Accepted by ish07
@ish07 wrote:
I have also attached the screenshot of the error messages.
Capture12
I strongly recommend to go back to the basic tutorials, because whatever you did here has no resemblance to my suggestion and makes no sense whatsoever. There is no reason for "initialize array" at the bottom, just replace it with this function and the rest will fall into place. Do you understand my suggestion? It also really helps to NOT hide wires underneath primitives. We cannot tell which output of the time function is connected in your image.
Message 13 of 14
(1,123 Views)
What are the names of the functions you used here?
Message 14 of 14
(897 Views)
