Add row to 2-D array on each loop iteration and update that 2-D array after each loop iteration
I want to create a vi that each row is updated every time after each loop of iteration. However, what I can do now is get all data at once in the array named "all results".
Any ideas or hints will be a big help to me.
Plu
(3,015 Views)
Accepted by PuriK.
Hello PuriK,
Try to adopt similar to the attached Code Snippet
(3,000 Views)
Accepted by PuriK.
Hi Puri,
The answer to this question is "THINK DATAFLOW!"
When you want to show data inside the loop (with each iteration) then the indicator has to be inside this loop…
(2,982 Views)
@GerdW wrote:
Hi Puri,
Sorry, I still cannot solve this issue. Could you give me more hints?
Ps. Can I unmark the solution mark?
(2,945 Views)
Hi Puri,
You already got a solution from Pazhanivel, what else do you need?
Yes.
(2,941 Views)
@GerdW wrote:
Hi Puri,
Sorry again. I checked your comment before Pazhanivel's solution. His solution is exactly what I am looking for.
By the way, thank you again for your comments on this topic and the previous topics. You have been helping me several times. I am looking forward to getting more help from you in the future.
Highly respect,
Plu
(2,921 Views)
@PazhanivelVenkatt wrote:
Hello PuriK,
Thank you so much for your help. This is a wonderful solution that can help me to finish this task.
Attach herewith my latest vi. I will try to make it more effective and clean in the future.
Plu
(2,920 Views)
