Add Polymorphic VI to User Libraries Palette
I have looked around for some documentation but have not found exactly what I am looking for.  I would like to add a polymorphic vi to the user library palette.  When I do this, by linking to the directory that holds the Polymorphic vi and its instances the new sub palette holds not only the polymorphic vi but also all of its instances.  Can someone point me to the directions I need to follow to get this to work?  Thank you for your help.
(3,162 Views)
Accepted by topic author jon_mcbee
While you can initially link to the directory to let LabVIEW create icons for all theVIs in there you then have to go to the button you created for that sublibrary and in the right popup menu disable the Synchronize option.After that you can go back into the subpalette and edit it, throwing out (deleting) everything you don't want in there and also rearranging the icons in the way you find logicial.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,154 Views)
Thank you Rolf.  I appreciate the feedback, I was not able to find any documentation on this.  You definitely saved me some time playing around.
(3,150 Views)
