ActiveX, Word 2003: struggling new user
I'm not new to LabVIEW, but I am new to using ActiveX and am struggling somewhat with the examples and understanding how they work, but I am muddling my way through.
I have hit a stumbling block however: I've added an ActiveX control to the front panel,gone to "add Activex object", "Create Control", but there isn't anything like
Microsoft Word Document,  which is what I am expecting.
Should I be using a control,  or should I be using "Create Document"?
For the record, here is what I would like to do & some background information:
I am working on a semi-automated system for a mechanical assembly. The system will guide assemblers through the assembly process, step by step.
The instructions for are in word document form.
What I would like to do is display the relevant page from this word document on the front panel, and hence step through page by page as the assembly progresses.
From what I understand, this should be possible.
Andy
(3,103 Views)
Forgot to add, I need/ am using use LabVIEW 7.1 for this application, although I have LabVIEW 8.5, but this won't be used for the application.
(3,102 Views)
Hi Andy,
There doesn't appear to be an easy way to make the Word document viewable in an ActiveX container as there is no ActiveX viewer for Office Word. There are viewers for PowerPoint and Excel.
Depending on how long the instructions are and how you wanted to control then i.r. scroll or just page by page, you could just hage each page as a JPEG file and use them as picture controls
Would that be a possible solution to your application?
Kind regards
Jordan Power
Applications Engineer
(3,051 Views)
I would suggest making a PDF of the document rather than trying to display a Word document. PDF is more transportable, and it doesn't require that you have Office installed on the target computer.
This question has come up many times before. The solution that's usually provided is to use the browser ActiveX control. Search around and you will probably even stumble on some code.
(3,045 Views)
