Action engine cluster loses data
Something wierd is going on.  I tried several things that made it work, but they don't make sense (as was stated previously).
no data
correct
also correct
Message Edited by vt92 on 09-24-2009 08:51 AM
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 11 of 19
(2,500 Views)
NI gurus: Is it possible that the data is not being copied into memory properly?
Message 12 of 19
(2,492 Views)
There is indeed something weird going on. I was incorrect when I said earlier that it was working correctly in 8.2. The issue does indeed seem to be that the data is not being copied. When you do something as trivial as multiplying the array by 1 before wiring it to the Bundle by Name element that forces a memory copy, and that's why that works. I can say that it does work correctly in LabVIEW 2009.
Message 13 of 19
(2,482 Views)
LabVIEW 8.5 introduced the "Always Copy" primitive under Application Control >> Memory Control.  Does using that solve the problem as well?
Message Edited by Ravens Fan on 09-24-2009 11:02 AM
Message 14 of 19
(2,474 Views)
Yes, that also works.
I noticed that the original version of his vi doesn't show any memory allocation (when using 'Show Buffer Allocation') between the unbundle and the bundle cluster.
Message 15 of 19
(2,461 Views)
Message 16 of 19
(2,453 Views)
I followed your link and found the text "super cluster" but I don't think I really understand it's definition.  I have AEs with more complex and larger clusters that work fine.  Having left out the waveform from the cluster as my final solution, maybe I have unknowingly moved from a super cluster to a non-super cluster.
Message 17 of 19
(2,405 Views)
Sounds super. But I agree, the Waveform sub-cluster is not complicated or large. Maybe it's a compiler issue.
Richard
Message 18 of 19
(2,397 Views)
Accepted by kc64
Otherwise known as a bug as in CAR 131499
that is listed in thebug fixes for LV 2009
Andrey reported it in this thread.
Ben
Message 19 of 19
(2,374 Views)
