Access DB insert Problem
Hi all,
         I am making an application which contains Access database.
Database contains "User_Info" named table which has 4 columns (ID,Name, Designation,Scale) and "ID" is AutoNumber .
Now I am getting a problem at inserting Data to User_Info table.I am passing 3 arguments (Name,Designation,Scale) ,
I am not passing the ID bcoz it is AutoNumber.
How to insert this Data to table??
Please help
Tnx
Message 1 of 12
(3,915 Views)
insert into user_info (D,Name, Designation,Scale) values (x, y, z, v);
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 12
(3,894 Views)
Microsoft Access - Database1  Database (Access 2002 - 2003 file format)_2012-06-15_09-00-57.png
That's probably your problem.  Rename that field and Bob will be your uncle.
Jim
Message 3 of 12
(3,890 Views)
His first problem was that he wasn't passing 4 parameters as required.
His second problem is that NAME is a reserved word in Access 2002 and later. http://support.microsoft.com/kb/286335
Message 4 of 12
(3,888 Views)
I only passed three parameters.
Jim
Message 5 of 12
(3,886 Views)
I am not sure what you are saying.
His table has four columns/fields, so he needs to pass 4 parameters. That is his first problem, and that is what he posted about.
Once he fixes that, he will run into the second problem which is what you are displaying.
Message 6 of 12
(3,882 Views)
Accepted by zzzzzabc
The OP was correct in his statement that he did not include the value for the ID field because it has a value of AutoNumber. If you do not explicitly provide a value for a field in an INSERT statement, the default value defined when the table was created is used; in this case autonumber.
As Jim indicated, changing the field name is the only change required. I don't know who Bob is though Smiley Tongue
Message 7 of 12
(3,871 Views)
I understand the concept of autonumber.
I always explicity include a NULL for the field that has the autonumber, e.g. INSERT INTO employee (id, firstname, lastname, address) VALUES (NULL, 'John', 'Doe', '123 Main Street'). Just what I am used to doing.
It wasn't clear to me what the OP had wired into the inputs of the DB Tools Insert Data.vi
I mistakenly believed the he had wired { ID,Name, Designation,Scale } for the columns input and was passing in only 3 elements in the data input. In which case, that wouldn't work.
Message 8 of 12
(3,863 Views)
I'm saying that my code snippet only passes three parameters into a table that has four columns.
@PhillipBrooks wrote:
[...] I don't know who Bob is though Smiley Tongue [...]
 Bob's your uncle!
Jim
Message 9 of 12
(3,857 Views)
Yes, as I wrote above I mistakenly believed that the OP was passing 3 parameters but specifying 4 columns names which wouldn't work. With no VI, you interpreted his statements one way, and Yamaeda and I interpreted another way.
Message 10 of 12
(3,854 Views)
