Accelerometer gives wrong signals
Dear all,
I have a problem with the signal I got from an accelerometer. I am doing a drop test and I have mounted an accelerometer on the bullet dropped in free fall. The objective of the test is to measure the impact force.
The accelerometer is a single axis accelerometer with capacity of +/- 10000 g. The accelerometer is connected with an amplifier and then to the NI6361. The module is then connected with a PXI 1073.
The bullet (steel) weight of 10.6 kg was dropped from 100 mm in a concrete base and the response I got was 3500g. I think this is unreasonable as the theoretical calculations in conjunction with the image analysis using a high speed camera provided me with the acceleration of 40g.
According to the supplier, each 1 Volt corresponds to 1000 g. Any help will be much appreciated.
Thank you,
Stath
Message 1 of 27
(5,309 Views)
What does the waveform look like? Is it possible that you have very high acceleration for a very short time, corresponding to a point contact impact? What is the resonant frequency of the weight?
Lynn
Message 2 of 27
(5,285 Views)
I am assuming the "g" stands for grams and not 9.81m/s^2. So what does it mean to have an acceleration of 40 grams?
Message 3 of 27
(5,280 Views)
Lynn and Gregory
Thanks for your replies. I have attached how the graph looks like in a pdf file. g is the Earth's gravitational acceleration of around 9.81 m/s^2. Please find below how the scale was configured using MAX.
Acceleration values of around 4000g for a falling object dropped from 100 mm are unreasonable, I think.
Stath
Message 4 of 27
(5,266 Views)
Do you have a link to the product page?
Message 5 of 27
(5,254 Views)
Can  you post the data sheet (or a link to it) for the accelerometer?
Lynn
Message 6 of 27
(5,250 Views)
The acceleration during dropping will be ~1g. The decceleration on impact can easily be 4000g because it happens over a very, very short distance and time if the floor and object are relatively rigid. Numbers seem reasonable.
At impact, you object will be going at a speed of about 5km/hour and will deccelerate to zero over a very small fraction of a millimeter. Do the Math!
Message 7 of 27
(5,244 Views)
Lynn, Altenbach and Gregory,
Thanks for your replies. I have attached the certificate for the one single axis accelerometer and the power supply settings. The signal is acquired using a voltage card and then is converted to g.
Altenbach -- During the impact event, I measured the acceleration using a high speed camera which gives almost the same result with the theoretical calculation based on the steel-concrete pulse width (impact force-time). Today, I have tried to hit a load cell from a distance of 50 mm using a weight of 10.6 kg. Because it is steel-steel contact (elastic collision), we expect the higher forces to occur. So the softer the material is, the longer the pulse width will be.
Again, I have a feeling that something is not correct with the settings using LabVIEW. I have checked many published papers that they used 600 kg from 1 meter free falling and the acceleration was not that high.
Stath
Message 8 of 27
(5,224 Views)
I am getting a drop time of .143s, and velocity 1.4m/s before hitting the ground. To have an acceleration of 4000g it has to lose this velocity in ~36us. Your graph separations are 1000us, so those spikes could be anywhere from 10-100us long, it does seem to make sense.
Message 9 of 27
(5,222 Views)
0.5 mV/g * 10000 g = 5 V.
It appears from the fuzzy image you posted earlier that your scaling is reversed: 5000 g => 10 V.
Lynn
Message 10 of 27
(5,214 Views)
