About compact field point controller_problem explained below in brief
Hello
We use compact field point controllers for our hydraulic test stand automation. The test sequence is programmed in Labview and deployed as .exe(application) on the test stand system. Labview program is done in such a way that after each test sequence is a report is generated in microsoft word format.
So from last two days, when ever test is carried on.....like we now get 2 test sequence data in one report.
Earlier it was programmed that 1 test sequence in one report, but now we are getting 2 test sequence data in one report.
I dont know what had happened.
If somebody know what might have happened. I feel that it is problem at field point controller end......because we can't comment about program as it is an .exe file. There is some time lag between controller and computer.
Regards
Kirit
(2,587 Views)
Kirit wrote:
Hello
Regards
Kirit
I would think we could rule out the software changing if you reloaded a backup of the exe.
"Self-modifying code went out of style a long time ago." (Rolf Kalbermatter).
Ben
(2,566 Views)
