Saving 2 strings to text file in 2 columns
I am trying to save two strings to a text file with the first string as column 1 and the second string as column 2 but can't get it to work right.
Thank you
(3,453 Views)
Well, what are you trying? Are you using the Write to Spreadsheet File function? Are you feeding it an array of strings?
(3,451 Views)
What I have done is attached. I am trying to use Write to Spreadsheet File. The first string is how I want it but the second is all in one row after the last element of the first string.
Thank you
(3,444 Views)
You are reading "index.dat", but you are not converting the string into an array of strings. The Build Array just gives you an array of one element, which is one big long string. You should use Read From Spreadsheet File instead of Read Text File so you can get an array of numbers. Then you can build your arrays.
(3,420 Views)
It works now. Thank you for your help
(3,385 Views)
