AbouT using Labview through Activex to control USB Camera
Hello All,
I have LV7.1, IMAQ6.0 . I can't use the IMAQ for USB Camera,
Someone suggest me try to use activex to control webcam.
Is activex can control the usb web camera?
How Can I use the activex to control the Camera?
Would someone send a simple example for me to observe??
Thank you!!
(3,108 Views)
Try this (LabVIEW Webcam Library) or consider following this guideline from NI.
Hope this helps, Guenter
(3,093 Views)
I've try the LabView Library before, but I find out that the frame rate very slow about 2 frame/second.
and it's respond time are quite slow.
Thank you
(3,078 Views)
