Problem with opencv function
I'm trying to use opencv library in my application, and meet the troubles. In the attached file 3 functions with following prototypes:
void cvSetErrStatus(long status);
CvMat* cvCreateMat( int rows, int cols, int type );
void cvFindHomography( const CvMat* src_points, const CvMat* dst_points, CvMat* homography );
As long as LV can't pass structures as out parameter of CLFN (CvMat is a structure), I use pointer to numeric value for structure passing from one function to another. The first two functions work properly, but the last one returns error. Any suggestions?
(4,258 Views)
Hi Err,
It seems like you are trying to pass the wrong type of parameter to cvFindHomography( const CvMat* src_points, const CvMat* dst_points, CvMat* homography ).  How did you configure the Call Library Function Node that calls cvFindHomography( const CvMat* src_points, const CvMat* dst_points, CvMat* homography )? Maybe you should try using I32 instead of I64 for the pointers. Hope this helps.
Yi Y.
http://www.ni.com/support
(4,235 Views)
