Abnormal Microsoft Office component popup calling Save Report to File VI
When I execute this code:
After the call to Save Report to File VI this dialog pops up:
The Activity Manager shows it as "Microsoft Office Component".
I think the problem comes from the report manipulation made before saving it.. like these:
I will try to disable such calls to see if they are responsible of such behaviour.
Does anybody had similar issues and fixed them in some way?
 Mike
(326 Views)
Disabling the graph creation and the following labeling removes the popup but of course I need the graph...
(303 Views)
A decade agp. I posted a "Revised Generate Excel Report Example" here on the Forum that included putting a Graph in the Worksheet.  Here's (a part) of what it just generated when I ran it:
Excel Demo.pngGranted, it's a minimal plot, but it's a demo, for goodness sake.
Why don't you post your VI (preferably in a version of LabVIEW 2021 or older (as I can't open LabVIEW 2025 (yet)), and enough "supporting VIs and data" that we could "try for ourselves" to make it work?  [Of course, if you are using LabVIEW 2025, and the RGT really is broken, all I can say is that it's been working fine for at least the last 12-or-so years ...
(271 Views)
You don't have to bother about LabView version since I'm still working on LabView 2013 🙂
The original (buggy version) VI could have some problem loading since it depends on many other external dependencies but here it's. I pointed the view on the inner case where the report is handled .. if it's not hope you can find it (the case is labeled UP CONVERTER...).
I fixed it removing the graph generation trough code and defined it (the graph) into the report template, I set it to be fed by a range of cells where I put some dummy data and then, at runtime, I filled such range with the real measured values;
this removed the chanche of bug and IMHO it is a much cleaner solution since the graph is visibile also into the template and can be modified in layout without the need of editing the code.
(255 Views)
