ASCII string to decimal string and its sum
Hello All,
I am a beginner in Labview and this is my first post on the forum.
I am receiving a serial packet "1200F" on the COM port from an MCU. These are all ASCII characters.
I want to convert all these ASCII characters to decimal numbers and add up their decimal values to get the sum. So I have taken the ASCII string into an array using "String to Byte Array" and then type cast this using constant type U8. I have put this in for loop and collecting the decimal value using Build Array function. Then I am "Add array elements" function to add these decimal values to get the sum.
The problem is that for input string I am able to get sum of "1200" only. The moment I type the last ASCII character F, the sum goes wrong. I see that when the sum goes above 255 it again resets from 0 onwards. I have attached the VI for reference.
Any help would be appreciated.
(4,720 Views)
hi
     you can change your dispaly numeric data type.
(4,705 Views)
Accepted by knikhil
Convert to U32 to avoid the 255 limitation of U8.
(4,704 Views)
Thanks JB, this works and more simpler than I was thinking.
(4,668 Views)
