How to make common control?
I wants to control the different channels into a single array.
20 Hz control the 5 channels(Another Sine Generator) and 30 Hz control the 5 channels(Another Sine Generator) and 40 Hz control the 5 channels(Another Sine Generator) and 50 Hz control the 5 channels (Another Sine Generator)
after then the results Mixed Plots.
Somebody help me.
Do you have Idea?
Message 1 of 11
(5,268 Views)
Hi Dusk,
you may start with using Ctrl-U (aka AutoCleanup tool). Then you should provide better icons for your subVI(s)…
When you have done this you should attach your VI(s) - we cannot debug any images!
Just a guess after looking into my glass ball:
When you use just the same subVI you should work with an autoindexing FOR loop…
Message 2 of 11
(5,251 Views)
Message 3 of 11
(5,186 Views)
So instead of posting an actual VI, you posted another image and an image that makes no sense.
Message 4 of 11
(5,169 Views)
And Anythig Else?
Do you have another Idea?
I need help...
Message 5 of 11
(5,159 Views)
Attached my file.
Please help me.
Message 6 of 11
(5,142 Views)
Are you trying to do this?
Message 7 of 11
(5,128 Views)
I'm sorry. It's not work.
And attached actual VI , I want control 16 channel Frequency.
Please Help me again.
regards
Message 8 of 11
(5,108 Views)
Hu Dusk,
you forgot to attach the subVIs. Next time please create a ZIP file containing all needed VIs!
Your example makes no sense at all! The FOR loop has no purpose here, all it does is (help) indexing the last element of your array constant as you just output the result of the last iteration!
It also makes no sense to state "I want just 5 plots", when you create an array containing 6 rows!
And you still don't use Ctrl-U as suggested in my first answer…
This is no valid error message. I never have seen this message in LabVIEW! Can you elaborate more details?
Why "16"? In your VI you seem to setup 6 channels with 5 frequencies!?
It's really hard to help you when you aren't able to provide necessary information…
Message 9 of 11
(5,086 Views)
My mistake.
Again attached SubVI.zib File
Please help me again.
Message 10 of 11
(5,072 Views)
