A .vi has to be able to change text and prices of another .vi! How do I go to do it?
Baisically, the user has to be able to put on a string control the price for taco_1 (confifure_taco_menu.vi). That price has to be modified on the menu screen (taco_menu.vi). how can I do this? Here is a screenshot representing what I want to do.
And a blockdiagram of my failed attempt. This is for a uni assignment.
Thanks!
(3,104 Views)
How are these VIs running? Are they running in parallel? If so you might want to look at using queues, notifiers, action engines or shared variables to pass the data between them. If one is effectively a dialog box used to initialize the other than you can define a cluster of the data (use a typedef) and pass that out when the dialog box closes.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,094 Views)
I am not sure. I am still learning.
I am using arrays for now, as there are not 18 outputs for the diagrams.
If I need something else, I'll come back here. Thanks
(3,085 Views)
Ow!
I said something similar about 12 years ago so to spare you learning the hard way...
Search for;
Action Engine these are used to share data between threads.
Type Definition - allows defining a data structure like a cluster (set of related data values)
Design Patterns - structure of programs to get you started
Bundle by name - to put data in cluster
Unbundle by name - to get dat out of a cluster.
Just trying to help!
Ben
(3,073 Views)
Hi Motanum,
Here is a tutorial about global variables, you can use them to interact between VIs that are running at the same time in your computer:
http://zone.ni.com/devzone/cda/tut/p/id/7585
Here are some exersices:
http://zone.ni.com/devzone/cda/tut/p/id/7517
Also if the VIs are running in different moments you can save the info into a file and then read it.
If your VIs are running in different computer you will need to create a Shared Variable:
http://zone.ni.com/devzone/cda/tut/p/id/4679
Take a quick look of it!!
Luis Elias
NI VeriStand and HIL Product Manager
(3,036 Views)
Why are you suggesting global variables? This is a very poor design choice and can lead to all kinds of issues with race conditions. This is not very good advice to give someone new to LabVIEW (I would go so far as to say it not good advice to anyone). This is even more surprising coming from a NI employee. With the exception of a WORM (write once, read many) I would never recommend using global variables. There are many better solutions as suggested above in this thread.
Mark Yedinak
LabVIEW Champion
(2,993 Views)
