08-26-2008 11:13 AM
In the BERT demonstration
http://zone.ni.com/devzone/cda/tut/p/id/3716
two example for BER tests are used.
Are those examples available for use and where they can be found?
08-27-2008 03:20 AM
Didn't got anything from the link you provided. But see this link and see if it helps you.
Mathan
08-27-2008 11:55 AM
08-28-2008 05:19 AM
I am familiar with the " niHSDIO Error Rate Test with Error Injection" example.
I am looking for a more standard BER tester example that uses a PN series and does not require synchronization between input and output.
I am aware of a BER vi in the modulation tool kit (which I don't have). But since I am working only with digital signals, I need it working with my HSDIO module
08-28-2008 09:55 AM
08-31-2008 03:51 AM
Thank you
09-17-2008 09:42 AM - edited 09-17-2008 09:44 AM
Hi Schmiddy,
The BERT example was recently added into the latest version of the NI-HSDIO driver as an example file. You can download the latest version of the NI-HSDIO driver from here. Once you install the latest driver, the example files will be installed with that as well. Open the NI Example Finder in your LabVIEW environment and Browse to Hardware Input and Output >> Modular Instruments >> NI-HSDIO >> Measurements >> Error Rate Test.vi.
This VI is very similar to the one used in the webcast. As Chris said, you can modify that VI to add the other features that you saw in the webcast. However, we will also post a slightly modified version of that on here soon (if you have not already implemented it).
Hope that helps.
Best Regards,
10-18-2011 03:11 AM
Hello all, I also want those two vi used in demonstration for bit error rate testing...
or any other with similar functionalities if possible.
Please help me if possible.
Thanks in advance.
10-19-2011 07:20 AM
Hi Jirav!
I'm not sure if the specific VI used in that video is available online, but I did find a similar example at http://zone.ni.com/devzone/cda/tut/p/id/7938. If you scroll down to the bottom of the page you should find a link to the VI.
Have a great Wednesday!
10-20-2011 01:17 AM
Hey Michael B.
Thanks for your help
appriciated.
