A question about Waveform graph
Thanks for the answers
When i use that procedure with the single waveform, the resetting function above the chart doesn't work. I need that function because i have to reset the chart in every measurement (every time i will run the VI).
Thanks in advance
Oesen
Best regards
Oesen
Message 11 of 13
(531 Views)
Your chart has a different datatype. Delete the DBL array, then right-click the chart history node and select "create constant". Now you should have the correct data type.
Message 12 of 13
(528 Views)
Hi Oesen.
This happens because we changed the datatype from a double to a waveform, but are still trying to reset the chart with a double. Simply delete this constant, and wire a new one into the property-node, by right clicking on the input and select Create => Constant. The new constant will have the waveform-datatype, and thereby fixing the broken wire.
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
Message 13 of 13
(526 Views)
