How can I determine if all values in a moving window/array are greater than x?
Hi everyone,
I have a problem that is driving me batty.... I have a strain signal and would like determine strain "onset" threshold as the point at which the baseline mean value exceeds 3SD... This is ok, I calculate this fine... My problem is that I want to define (and find) the strain threshold onset as the point at which ALL elements within a moving window (length of 100 data points, step of 1 data point) are greater that the threshold value..... Hopefully this will reduce any false triggers, so to speak.. So for a 100 data point window, the outcome of the for loop with the 100 element subarray should be either 0 (1 or more elements DO NOT exceed the threshold) or 1 (ALL elements exceed the threshold).
I have made some subvis for calculating moving average RMS data and indexing values based on comparison functions (i.e. find all indices> 3); but I cannot merge elements from both subvis to give me want I need... MVC EMD and RTD attempt to solve this problem.
As an Exercise Scientist (no formal EE background at all) I am getting my head around basic labview programming concepts...Any help with this is problem would be greatly appreciated... I have spent 5 hours on this! Ahh!
Jack
Message 1 of 18
(4,867 Views)
Jack,
Something like this should do it.
Message 2 of 18
(4,852 Views)
Hello; I make this program in the past for my project ,i think you can use it in your program ; this program take array and delete all values equal to X Value;
Forza Juventus
Message 3 of 18
(4,833 Views)
Accepted by topic author jcannon
Here's a slightly more optimized method.  Eliminated the extra array and combined the loops done inside of the primitives.
Message 4 of 18
(4,826 Views)
Forza Juventus
Message 5 of 18
(4,817 Views)
Which program you are talking about. If you have the code you are welcome to share the code
Message 6 of 18
(4,812 Views)
Building both suggested techniques provides an interesting result when the timing of both is profiled. If all values of the array aren't greater than the threshold value they both take the same time, even for pretty large arrays (100,000 values). But if all the array values are in fact greater than the threshold then the one based on LabVIEW primitives (the first case) is 3 times faster on average. LabVIEW 2011, Windows XP, i5-250, 3Gb memory.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 7 of 18
(4,802 Views)
You posted this twice, so you must think it is really important. However, this is a different problem and has nothing to do with the topic of this thread.
  • If you have a question, start a new thread.
  • If you think you found an especially efficient and cool solution, write a hugget.
A program that takes an array and deletes all values equal to x will probably only work well for integers, because in floating point the definition of equal is a bit of a problem in general. Does your program remove all array elements that match X, making the array smaller, or does it set all matching elements to zero? Plenty of efficient in-place solutions have been discussed here in the past, but please share your code if you think it is worth sharing.
Message 8 of 18
(4,799 Views)
Also, don't forget the ptbypt functions.
Message 9 of 18
(4,790 Views)
Hi everyone,
Thanks for all your replies... Wayne's and Crossrulz solutions both worth well.... I can't really notice the difference in timing between the different approaches in my instrument... The code is for offline data analysis, so an extra second or so doesn't really matter...
Everytime I think I am getting better using Labview, people post responses such as these that solve my problem using very eficient code using appropriates I am not aware.... My attempts are MUCH less efficient.... Back to kindy for me!
Thanks again.
Jack
Message 10 of 18
(4,778 Views)
