A few simple questions
Hi, I'm a labview newbie and it'll be helpful if someone can help me with the following questions!
1. How can I create a 3x3 matrix.
2. How can I multiply two complex numbers in labview?
thanks in advance.
(2,936 Views)
1.  I could be wrong on this but I think a 3x3 matrix in LabVIEW is equal to a 3x3 array so you should be able to use the build array VI for this.
2.  See attached picture for multiplying two complex numbers.  In order to make one on the front panel you should right click the control and change its representation to what you need (complex single/ double/ extended).
Message Edited by Chaos on 09-12-2005 10:54 AM
(2,929 Views)
Hi Shibu,
See attach file, hope this will be of interest for you.
Epictetus
Antoine Chalons
(2,928 Views)
You may also find the VI called complex A X B.vi interesting
it is under Analyze/mathematics/linear algebra/complex linear algebra. However if you only have the base edition you will not have it.
Joe.
"NOTHING IS EVER EASY"
(2,914 Views)
You can e.g. create a 3x3 2D array using "initialize array" or with 2 stacked FOR loops. There are many other possibilities.
To mutiply two complex numbers is just use the plain multiply node. It will do the right thing. 🙂
Attached VI (LabVIEW 7.0) show a few examples.
Message Edited by altenbach on 09-12-2005 10:28 AM
(2,894 Views)
