12-15-2009
06:02 AM
- last edited on
10-20-2025
10:53 AM
by
Content Cleaner
Hi!
I'm trying to learn the 9211 module, and I used the Getting started 9211-example, and it worked but readings were off with two degrees. Then I found this: http://digital.ni.com/public.nsf/allkb/AAEC7BF96A019EFB862570E4006D9204
I downloaded the file, replaced it with the old library and tried it again. Now it doesn't work at all. There are conflicts between VIs and when I'm trying to re-complile and wants me to save the project, I havn't got access to save it.
After a while (not any more though) I manage to make it work, but then the resultat was raw data. Does this library work at all?
Tim Jansson
12-16-2009 01:46 AM
Hi Tim
What version of LabVIEW are you on? Were you seeing the offset at just very high and low temperatures like the KB says or at all temperatures? What project is it prompting you to save and what are the conflicts? In your project you should have a Resolve Conflicts button that can help you resolve conflicts in your project.
Best Regards
David
NISW
12-17-2009 01:19 AM
Hello!
I'm using LV 8.6 at the moment. But I think I got it working. It was 2 degrees off, even at low temperatures. I think it got something to do with the TC. I havn't tried it at higher temps yet, but I will do this later today.
Tim Jansson
12-17-2009 02:28 AM
Ok, let me know how it goes.
Best Regards
David
12-18-2009 01:17 AM
It worked fine up to 120 degrees, so it should not be a problem for our tests.
Thank you!
Tim J
