check in vis Programmatically
I want to develop a program which can:
  1. Check in
  2. Get Latest version
  3. check out
  4. Assign Labels
VIs, Folders/ Documents from Microsoft visual source safe (VSS). Will it be possible to check out the folder/ document/ vi with a perticular "Label"?
Can any one guide me on this further? Sample code will be of great help. Also a document/ paper/ link on this forum will be helpful.
ThanX!
(3,494 Views)
If you have the LabVIEW Professional Development System, you have access to the SCC API using the palette in Connectivity >> Source Code.
Without the PDS, you will have to write your own API (if possible at all.....)
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,488 Views)
it is possible to have make all the SCC fsunctionalities by writing your own API/
There are command line help for SCC (for VSS).. Just follow them and make your own application.
Actaully there is a "VISTA PM tool" from "VI Engineering" which provides all and more functionalities.. Just check their website
Regards
Guru (CLA)
(3,476 Views)
Thanks!
I'll try to serach for the command lines and API. But these commands works with Windows command prompt or do I need to have any other utility?
I don't have the PDS version. I have FDS version.
(3,454 Views)
they all will work with the windows command prompts.
As mentioned by norbert if you have a pds you dont have to go for writing your own API's.. They are already there...
Message Edited by Guruthilak on 12-18-2009 11:54 AM
Regards
Guru (CLA)
(3,451 Views)
