8 point moving average filter
How to implement an 8 point moving averge filter for a sample size of 1000?
Message 1 of 12
(7,905 Views)
There are many ways to do this.  One of my favorite is to just use an FIR Filter.  But the most straight forward way is to use the Mean Pt By Pt VI inside of a FOR loop.
Message 2 of 12
(7,898 Views)
Its not working as i have stored my input samples in an array.
Message 3 of 12
(7,860 Views)
check these links below
Moving Average Filter w/ continuous data acquisition
http://forums.ni.com/t5/LabVIEW/Moving-Average-Filter-w-continuous-data-acquisition/td-p/2571975
http://forums.ni.com/t5/LabVIEW/Moving-Average-Filter/td-p/2550513
Message 4 of 12
(7,845 Views)
Hi, sorry to reanimate this thread. Why would one use the FIR Pt By Pt instead of Mean Pt By Pt for a moving average filter?
Message 5 of 12
(6,701 Views)
I wouldn't! You need an 8 pt moving average, use the mean pt By pt.
"Should be" isn't "Is" -Jay
Message 6 of 12
(6,698 Views)
You don't tell what is "not working", but if you want to use "mean ptbypt", simply wrap a FOR loop around it and autoindex on the array, right?
 Of course you can also process the array directly, such as convoluting with an array containing 8 elements with a value of 1/8, then trim back to size.
(we need to trim because we don't have the output size option for 1D arrays Smiley Sad)
Note that the ptbypt version has a startup distortion for the first 7 points because fewer points are averaged at the beginning. Of course you might want to shift the subset start for the convolution version to eliminate the filter delay. (not shown)
Message 7 of 12
(6,685 Views)
Try the below method.
CLD Using LabVIEW since 2013
Message 8 of 12
(6,657 Views)
That is NOT scalable! Most of the entire code would need to be rewritten if the history length should be changed to something else. What would you do to make a 1000 point average instead? Get a much bigger monitor? 😄
A properly written, scalable solution only need to change a single integer value to work with any history length. try it! 😉
(See also my NI Week presentation (Part II) where I compare four different running average implementations)
Message 9 of 12
(6,643 Views)
Hii, I have send you an PDF. You will get the whole information, hope that helps. Be sure to share results.
Message 10 of 12
(6,621 Views)
