6221 and grounding issues (eventually).
I am using the attached vi (modified from sound and vibration toolkit), on the 6221 DAQ.
I am using the output channels and input channels as suggested.
I am using an RC circuit (1kohm, 1mF) in serie to test it.
Yet, I have quite a few issues in choosing the best mode (RSE, NRSE, differential, pseudodifferential...).
Currently, in RSE, I have an issue in AI1 : even when the wire is not connected, I am still recording a signal quite similar to AI0. I am actually reading it from any channel not connected. It is not noise because It has the same sine wave oscillations, and offset.
I assume this could be due to grounding issue, which I don't know much about. Any clue/suggestion on that matter?
Kentmey
Kentmey
(2,775 Views)
(2,771 Views)
try tconnecting the un-used channels to ground.
Cross-talk between channels is often the result of the residual charge on the input capacitance not being bed-off when switch channels in the sampling process. This alos occurs when the sources of signals have a very high output impeadence.
Ben
(2,771 Views)
What unused channels ? all other AI (make 14 channels...)???
Could differential for both channels and putting - to ground make the trick?
Kentmey
(2,768 Views)
