50MHz Arbitrary Waveform/ Function Generator 3390
I am new in learning Labview 2013. I have the Labview programm about the function generator 3390. My problem is that how can i  set up a periodic Ramp wave with idle time intervel (5s)? and the idle time interval can be changed bei labview programm.
Thanks a lot
(4,571 Views)
Thanks a lot
Is that an NI device?
Ben
(4,566 Views)
It looks like it's made by Tektronix/Keithley. The specs say it has a sampling rate of 125 MS/s, so if you want a ramp with a frequency of 50 MHz, that only gives you 2.5 samples per cycle, so it's not going to be much of a ramp.
(4,563 Views)
It is made by Tektronix/Keithley. I find the similar case on function generator HP 33120A, it calls burst wave. How can i realise this control with Labview programm?
(4,523 Views)
(4,521 Views)
Accepted by topic author Marumaxxxxx
You need to read the manual and program it remotely.  We use the Tektronix AFG3102C for a similar purpose.  It will require about 12 commands to configure it properly.
  1. Set Output Off
  2. Set waveform shape (Sine)
  3. Set voltage level (1Vpp)
  4. Set mode (sweep)
  5. Set start frequency
  6. Set stop frequency
  7. Set sweep mode (manual)
  8. Set Hold timer
  9. Set Return timer
  10. Set ramp timer
  11. Set output On
  12. Send Trigger
Now check response.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,512 Views)
