5.0Window behavior ("Floating")
I have recently started experimenting with LabVIEW NXG 5.0 where I try to get some of my LabVIEW 2020 applications, using "User32.dlll", to work.
So far so good, but the "SetForegroundWindow" function that does not work as intended as I think the reason is (in my case) that the application window is not running as "floating".
Does anyone know where/how to set whether the window should be "Default / Floating / Modal" ? 🤔
________________________________________________
"Science is about knowing, while engineering is about doing"
Message 1 of 1
(2,055 Views)
