3D- Time
i want to plot 3D-graph and the x-axe must be Current time...
I couldn't plot Current time on my 3d-graph...
can anybody help me?
Message 1 of 9
(4,723 Views)
Copy of this post.
JamesC
NIUK and Ireland
Message 2 of 9
(4,716 Views)
Hi Hakan,
I have modified your code slightly so you enter data into the X-Matrix, you will need to modify the data going in to get accurate results on the graph, but this should put you on the right track.
Regards
JamesC
NIUK and Ireland
Message 3 of 9
(4,713 Views)
Thanks alot for your reply JamesC.
but i cannot see the current time on x-axis.. time starts, and then it becomes 00:00:00
do i make a mistake?
Message 4 of 9
(4,711 Views)
Hi Hakan,
That's what i meant when I said you needed to modify the code a bit, I need to know how you want you time axis to look like, do you just want time. what will the dT be between each point.
I need some more info before I can do more.
Regards
JamesC
NIUK and Ireland
Message 5 of 9
(4,703 Views)
Hi JamesC,
now i understand you. i want to display time axis in munutes..
Message 6 of 9
(4,699 Views)
Post conflict!
I retract my previous.
Ben
Message Edited by Ben on 03-17-2006 07:07 AM
Message 7 of 9
(4,700 Views)
Hi Hakan,
Here is the code modified, I needed to convert from LV time format to VB time format as the ActiveX control is made in ComponentWorks, which was written in VB. You can find the KB explaining this here [broken link removed; article no longer available].
Hope this is what you are looking for
Regards
JamesC
NIUK and Ireland
Message 8 of 9
(4,683 Views)
hallo JamesC
i'm sorry that i didn't reply. It works, but...
i want to see current time, not the time(seconds) which we are starting..
Thanks..
Message 9 of 9
(4,655 Views)
