3D- Time
i want to plot 3D-graph and the x-axe must be Current time...
I couldn't plot Current time on my 3d-graph...
can anybody help me?
Message 1 of 9
(4,512 Views)
Copy of this post.
JamesC
NIUK and Ireland
Message 2 of 9
(4,505 Views)
Hi Hakan,
I have modified your code slightly so you enter data into the X-Matrix, you will need to modify the data going in to get accurate results on the graph, but this should put you on the right track.
JamesC
NIUK and Ireland
Message 3 of 9
(4,502 Views)
Thanks alot for your reply JamesC.
but i cannot see the current time on x-axis.. time starts, and then it becomes 00:00:00
do i make a mistake?
Message 4 of 9
(4,500 Views)
Hi Hakan,
That's what i meant when I said you needed to modify the code a bit, I need to know how you want you time axis to look like, do you just want time. what will the dT be between each point.
I need some more info before I can do more.
JamesC
NIUK and Ireland
Message 5 of 9
(4,492 Views)
Hi JamesC,
now i understand you. i want to display time axis in munutes..
Message 6 of 9
(4,488 Views)
Post conflict!
I retract my previous.
Ben
Message Edited by Ben on 03-17-2006 07:07 AM
Message 7 of 9
(4,489 Views)
Hi Hakan,
Here is the code modified, I needed to convert from LV time format to VB time format as the ActiveX control is made in ComponentWorks, which was written in VB. You can find the KB explaining this here.
Hope this is what you are looking for
JamesC
NIUK and Ireland
Message 8 of 9
(4,472 Views)
hallo JamesC
i'm sorry that i didn't reply. It works, but...
i want to see current time, not the time(seconds) which we are starting..
Thanks..
Message 9 of 9
(4,444 Views)
