3D Surface Plot Helper To Dynamic Array
Ah, yes. I suppose that that's the first thing I should've tried. 😅
Thank you, good sir.
Message 11 of 14
(1,187 Views)
@CNLSN wrote:
I've tried your .vi and I'm receiving the numbers into the array but it looks something like:
Sensor 2 | Sensor 1          instead of             Sensor 1 | Sensor 2
Sensor 3 | Sensor 4                                       Sensor 3 | Sensor 4
Is there a way to define the placement of the sensors (paticulary, with respect to the graph)?
Are you sure about that? reshaping will keep the elements in memory order, so a 4 element 1D array input:
ABCD
reshape to 2x2 will result in:
AB
CD
Just look at the 2D array indicator. This does not translate to the graph, of course, because you can have an arbitrary viewpoint.
@CNLSN wrote:
Yes, of course - the strings look like "A11B12C13D14"..
So your values in the string are integers? Why are you scanning them as floating point?
Message 12 of 14
(1,178 Views)
Correct, but were I to add more variables - say 2 X 3 - would that still result in:
ABC
DEF ?
That's correct. If I wanted to scan them as an integer only, would that be %g attached to the scan from string function?
Message 13 of 14
(1,168 Views)
No, you would use %d
ABC
DEF ?
It would have been faster to just test it instead of asking questions here. 😄 Of course you need to change the sizes accordingly when reshaping. (or calculate the number of columns from first principles if you always have two rows.)
Message 14 of 14
(1,164 Views)
