3D Picture: Applying Different Textures to Faces of a Cube
Accepted by Cepera
I am not so adept at 3D so I tend to keep it simple, but I have done something similar before.  See if this helps you out.
Message 11 of 20
(5,262 Views)
Hi Darin,
This is exactly what I was looking for. Thanks for sharing!
Sergey
Message 12 of 20
(5,253 Views)
I need something like that, but I need a head instead of cube. I could use "creat sphare.vi" and "Apply Texture.vi" to stick a 3D face on the sphare. It's working and I can rotate the head(Sphare) but I need a mesh like human head instead of sphare, so that it will look like a real 3D head. I've attached what I had.
Message 13 of 20
(4,597 Views)
How can I create 3D oval to use it instead of spheral. then it will be a little like the head?
Message 14 of 20
(4,594 Views)
Labview offers a way to automatically apply texture to its standard 3D shapes like cube, sphere, cone, cylinder, etc. If you want to apply a texture to any shape that is not LabVIEW standard, you will have to upload the shape, like a .stl, and apply the texture coordinate that you might create in software like Blender. That is not an easy task you have not done it before.
Marc Dubois
Message 15 of 20
(4,567 Views)
You can apply a scale transformation to the Sphere along one of it's axes to make a 3D oval.
Message 16 of 20
(4,536 Views)
Thank you Marc
Message 17 of 20
(4,518 Views)
Thank you Pauldavey
Message 18 of 20
(4,515 Views)
Hi Darin. I know this post is old, but How could I modify the polygon parameters? (Deep high width)
Message 19 of 20
(2,957 Views)
Expand the Front Panel and you will see the controls for the vertex array.  It has 6 rows, one for each face of the cube.  Each face is defined by 4 vertices.  Just change the values accordingly.
Message 20 of 20
(2,936 Views)
