09-30-2020 02:54 PM
I've noticed that when I'm typing in a free label (on either FP or BD), the "Return" and "Enter" keys behave differently.
By "Return" key, I mean the key on my keyboard labeled "Enter" that is by most of the keys, e.g. the alphabet.
By "Enter" key, I mean the key labeled "Enter" that is by the Numpad on my keyboard.
Different OS's and
When I am typing in a free label,
How did I discover this?
Personally (right-hand on mouse, with a physical keyboard next to my right hand), I often reach my thumb over from my mouse to press the "Enter" key - for example, to insert a couple "\n"s after clicking the end of a block of text and before typing a new paragraph.
It took me weeks to figure out why I sometimes couldn't insert a new line on my free labels...
Why are these two keys programmed to behave differently? It seems like a bug to me.
I was about to say that if this is a feature, that it should be documented... but then I looked more closely at Creating Free Labels - it turns out it *is* documented, and really is a design feature. Just one that I find unintuitive.
So in the end, it turns out I don't have a question (or Idea Exchange post) after all.
I'll still post this so that if someone else thinks they found a bug like me (and is also lazy like me, i.e. they don't carefully read Creating Free Labels), they can understand that it's not a bug, it's a design feature. 😅
-joeorbob
Solved! Go to Solution.
09-30-2020 04:48 PM
Try playing with this setting if you don't like how it is by default:
09-30-2020 05:47 PM
OK, confession, I got a little Solution-trigger-happy there...
I was so shocked that there was a setting to adjust what I was trying to do that I was like, WHA-??!!!
But sadly, that setting is not what I want.
To explain, that setting *does* make the "Enter" and "Return" keys behave the same...but it makes them both behave like the "Enter" key, and I want them to both be like the "Return" key.
I'm OK with leaving the "Marked as Solution", it just turns out it's a solution I don't particularly like. 😉
Thank you so much, @BertMcMahan, for teaching me about a setting I didn't know existed.
-joeorbob
