3D Cad Model
I am new to labview. I want to import a cad model of a flexible shaft which I will build in solidworks and then using labview 3d picture I want to simulate the bending in shaft. Data will be acquired from the actual setup using proximity sensor. My end goal is to display realtime bending in shaft in labview 3d picture control. Kindly suggest me starting point I have basic knowledge of labview and cad model design.
(2,630 Views)
Hi, @Airian_007
Using Google, I managed to search for "labview import 3d picture". 😉
The first four links are
I recommend you convert your CAD model file to STL format and try some of these examples.
joeorbob
(2,553 Views)
