3 way vertical toggle switch
can we have 3 way vertical toggle switch, with unstable position at top, neutral position in center and stable position at bottom
Message 1 of 40
(12,167 Views)
use a slider control, but set the type to integer instead of double and coerce the range from 1 to 3. The slider will then take on one of three values.
Message 2 of 40
(12,153 Views)
If you want something that looks a bit more like the standard switches, I've made some that use the picture control.
If you're interested, you can read a bit more and download them here.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 3 of 40
(12,144 Views)
I need to substitute a two ways switch in a four ways switch. Do you know if this is possible? Thank you.
Message 4 of 40
(12,087 Views)
Hi Aurelia,
You can modify the example given in this document:
How to Create a Three-Position Vertical Switch [link removed; example no longer available]
to have a 4 way switch. The example gives step-by-step instructions to do that when you click on the Help button (however, note that this example is written for LabVIEW 5.0.1 so some menu options in later versions of LabVIEW are slightly different).
Hope this helps and let me know if you have any questions about it.
Good luck!
Shakhina P.
Message 5 of 40
(12,045 Views)
hello sir,
thanks for giving your valuable suggestions but sir what i want is is to have 3 way vertical toggle switch, with unstable position at top, neutral position in center and stable position at bottom. MOST IMPORTANT the shape of the switch should be same as that of vertical toggle switch.
Message 6 of 40
(12,016 Views)
hello sir,
Message 7 of 40
(12,016 Views)
Hi Ed,
Thanks for the link to your page. In all of my google Labview searches, I hadn't come across your page yet. I think we need a forum section where people can put links to their Labview homepages.
Message 8 of 40
(12,008 Views)
Avon: Try the attached vi. It has a 3 way switch control.
- tbob
Inventor of the WORM Global
Message 9 of 40
(11,982 Views)
thanks a lot buddy.... i think this will solve my problem... thanks once again..
Message 10 of 40
(11,953 Views)
