2 hours finished the webcam program
Hi, I believe someone already asked, but I didn't see a reply. I am "OK" with labview, but new to ".NET" and am tryign to figure out how to save an image from this Webcam vi. Any help would be appreciated. I have been trying to read up on the imag.save function for the picturebox, but not having any luck.
thanks
Keith
Message 21 of 84
(13,625 Views)
Post what you have did so far? That will be easy for us to guide you.
Mathan
Message 22 of 84
(13,615 Views)
Looking at the original code, and reading about the Picture Box control, I expected to be able to create a new property node for PictureBox similar to the one which is there for getting the Handle. Then wire the handle to it and select the "image.save" function from the drop down list. I quickly discovered that there is no "image.save" function shown in the drop down list. I am trying to get time to do more research on this, but any helpful hints would be appreciated.
thanks
Keith
Message 23 of 84
(13,569 Views)
If you mean property node then you probably should instead create a method node. Save certainly is an operation and not a property of an object.
If you already created a method node and couldn't find save there, then I would think that .Net control does not have a save method.
Rolf Kalbermatter  My Blog
Message 24 of 84
(13,557 Views)
Hi, This is a really handy vi. Thanks McArthur.
Has anyone figured out a way to save an image from this?
Message 25 of 84
(13,282 Views)
Hi, James.
I have downloaded your revised Webcam.vi
I see only a black screen.
Win XP sp2, LV2009
The Web Cam video I am using DOES show up as working
when I use it with Skype.
Is there anything I'm missing?
JIM
Message 26 of 84
(13,153 Views)
I just ran this piece of code and saw a black screen also
once the camera is turned on and no other program is using the camera it works
- James
Using LV 2012 on Windows 7 64 bit
Message 27 of 84
(13,153 Views)
Thanks, James.  That worked for me when I closed down Skype.
JIM
Message 28 of 84
(13,126 Views)
yes, that is the solution...
Working...
Message 29 of 84
(12,956 Views)
Nice one Smiley Happy
attached in labview 8.6 openable version
kudos welcome
Message 30 of 84
(12,932 Views)
