‎09-27-2012 02:55 PM
When I open my main.vi from project manager another vi opens up with it. Not really a problem but a little strange and annoying. LV2011.
‎09-27-2012 03:48 PM - edited ‎09-27-2012 03:53 PM
If it is always the same VI that opens, that VI is probably set to open its front panel when loaded. Look in VI Properties->Window Appearance->Customize. Right-hand Left-hand side, bottom checkbox.
‎09-28-2012 06:14 AM
Of course. Don't remember setting it, though. ![]()
‎09-28-2012 07:05 AM
If you ever setup the VI as a top level application window in the Appearance settings, that would have checked the option. If you went from that to customize, you would have had to manually uncheck it.
‎09-28-2012 07:10 AM
That's what happened. This vi is a top-level from another application.
