2 VIs open when I double-click main.vi in project manager
When I open my main.vi from project manager another vi opens up with it. Not really a problem but a little strange and annoying. LV2011.
PaulG.
Retired
(3,211 Views)
Accepted by PaulG.
If it is always the same VI that opens, that VI is probably set to open its front panel when loaded.  Look in VI Properties->Window Appearance->Customize.  Right-hand Left-hand side, bottom checkbox.
(3,203 Views)
Of course. Don't remember setting it, though. Smiley Happy
PaulG.
Retired
(3,173 Views)
If you ever setup the VI as a top level application window in the Appearance settings, that would have checked the option.  If you went from that to customize, you would have had to manually uncheck it.
(3,164 Views)
That's what happened. This vi is a top-level from another application.
PaulG.
Retired
(3,160 Views)
