Реализовать задачу на Labview
Всем привет! Я новичек и у меня вопрос, как реализовать такую задачу на Labview. Буду признателен за любую подсказку и за указания правильного направления.)))
(3,332 Views)
I do not think that Google Translate can translate a png of rusian text to English (yet).
Start by using Google Translate to share your question.
That is the first hint.
Ben
(3,329 Views)
Ben
Hello! I'm a newbie and I have a question how to implement such a task on Labview. I would appreciate any clue and for pointing the right direction.
Need a better hint or translation. ( Нужна лучшая подсказка или перевод )
mcduff
(3,325 Views)
I. If the modulus of the sum of negative elements is an integer
matrix is ​​greater than the sum of its positive elements, to form
one-dimensional array of the first elements of the matrix rows, otherwise the array
formed from the last elements of the rows of the matrix. If in the matrix
no positive or negative elements, withdraw
message, otherwise print:
• sums of negative and positive elements of the matrix;
• resulting array.
Ii. Find and display the coordinates and the value of the maximum element
matrices with two even indices.
(3,308 Views)
The google translate app can deal with images directly, here's whats on the image (no guarantees ;)):
"If the modulus of the sum of negative elements of an integer matrix is ​​greater than the sum of its positive elements, they will form an atomic array of the first elements of the rows of the matrix, otherwise the massi is formed from the last elements of the rows of the matrix.  If there are no positive or negative elements in the matrix, output a message, otherwise output: the sums of negative and positive elements of the matrix;  .  resulting array  Find and display the coordinates and the value of the maximum element of a matrix with two even intexes"
You can even point the camera to a sign or other text and the picture will show the translation.
(3,307 Views)
• resulting array.
This still does not make a lot of sense, even translated into English. Do you have some example data and expected result?
(Это все равно не имеет большого смысла, даже переведено на английский. У вас есть пример данных и ожидаемый результат?)
(3,298 Views)
I could have used that when I was in Jerusalem (if it existed 9 years ago) but would have deprived of the joy of trying to read the Hebrew myself.
Spoiler
Will it translate G to C  OR C to G ?
Ben
(3,293 Views)
