06-07-2016 08:21 AM
I 'd like to detect what sensors/actuators are connected to what ports in my EV3 brick. I'd like to do it in labvew if possible, or using the lego mindstorms software.
Solved! Go to Solution.
06-08-2016 09:08 AM
Hi gpesma,
I'm not sure what you mean by detect. What are you looking for to show a sensor was detected? Also, what sensors/actuators are you using? From what I understand the Lego sensors should be relatively plug and play. Links to the sensors you are using would be helpful here.
Aaron F.
06-08-2016 09:35 AM
I am using the standard lego sensors (touch,gyro,ultrasonic, color) and the standard motors which are included in the educational edition of lego mindstorms. My goal is to write a program in labview that acts differently depending on what sensors/motors are attached to it. So I want my program to know that for example there is a touch sensor on port1 and two motors in ports A&B if that is the case.
06-08-2016 09:43 AM
Hi gpesma,
Are you trying to use this in a program that's target to computer or target to EV3? If you are doing target to EV3, you can use an Invoke Node. Right-click on an invoke node and select class EV3InputPrimitive to access the InputGetTypeMode method. The types and mode numbers are documented on page 100 of the firmware developer kit .
06-08-2016 10:02 AM
That sounds about right. What should my inputs be in that case if I want my outputs to be the type and mode. See picture.
06-08-2016 10:21 AM
The "layer" input refers to the daisy chain layer. If you don't have multiple EV3s daisy chained together, it's 0. The "no" input is sensor number, "0" for sensor port 1 and so on.
That method will only help with sensors. For the motors, you may need to rely on moving the motors slightly and testing tachometer counts.
