11-25-2008 06:18 AM
I am trying to program my NXT module using the LabVIEW NXT Toolkit.
I have exactly copied the volume waveform chart from Getting Started with the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT: ftp://ftp.ni.com/evaluation/mindstorms/LabVIEW_Toolkit_for_LMS_NXT_Getting_Started_Guide.pdf
The NXT terminal connects to my NXT module fine, but when I download the program it appears in the NXT files as just .rxe (i.e not program.rxe, the name is completely missing). When I navigate to the program on the NXT module and press run I get a message saying 'File Error!'.
Any suggestions as to what I may be doing wrong?
Sarah
11-25-2008 08:13 AM
01-08-2009 02:13 PM
01-09-2009 02:38 AM
https://lumen.ni.com/nicif/us/evallegotoolkit/content.xhtml
Under the download links.
It says it's a patch for "LabVIEW 8.5 and localized (non-English) versions of LabVIEW", but I'm also using LabVIEW 8.6 and it worked fine. As far as I remember you just have to copy some files to the right place, but the instructions will tell you what to do.
01-09-2009 10:19 AM
01-09-2009 10:56 AM
01-09-2009 11:11 AM
Oh, that's ok, thanks a lot for the help
