LabVIEW Web UI Builder and Data Dashboard
取消
显示结果
搜索替代
您的意思是:
labview + ios iphone
hey, what's up . i'm trying to connect my ios device with a shared variable but it gives me a error. "cannot connect to the server" please help me. i tried my a local adhoc network, i added a static ip's  + such as , CIP 192.168.1.1 , subnet mask 255.255.255.0 and gateway 192.168.1.2(my ios device) but the same error apeared so, i also tried with the hotspot network of my cellphone but it was more easy because the ip's were designed by DHCP. maybe i'm doing wrong in any step of labview, anyone can help me?
0 项奖励
1 条消息(共 4 条)
8,223 次查看
hahaha, finally i got it, the problem was the windows firewall. 😄
2 条消息(共 4 条)
8,218 次查看
Great!
Remember that you have to be connected to the same network to use Data Dashboard..
0 项奖励
3 条消息(共 4 条)
8,190 次查看
You only need to be able to access the server and the right ports. You do not have to be on the same network (unless you count "The Internet" as one single network).
0 项奖励
4 条消息(共 4 条)
8,186 次查看
