LabVIEW Public Beta Program in 2024
Sluggish IDE Performance on Linux
I am seeing very sluggish behaviour from the IDE when editing the block diagram in non-trivial VIs in the LV2024Q3 second phase (Second phase of LabVIEW 2024 Q3 Beta Program - NI Community)
I have attached a video where I first try and draw a wire and it takes many hundreds of milliseconds to draw the "this is where the wire is going" dashed line. After that I try and nudge a wire along by briefly holding the right arrow key and it takes many seconds for the wire to slowly crawl to the right.
I don't have these issue with LabVIEW 2022Q3 on this system.
This is running on a laptop with the following
Intel Core i5-6200U (2.3GHz)
8GB Ram
Ubuntu 22.04.4 LTS (Xubuntu Desktop)
OpenGL Render: Mesa Intel HD Graphics 520(SKL GT2)
(1,911 Views)
Can you please let me know if you continue to see this issue with the released version of LabVIEW 2024 Q3?
Christina Rogers
Principal Product Owner, LabVIEW R&D
(1,796 Views)
I think it seems quite similar unfortunately - editing and navigating on a BD with many nodes is slow to respond.
I have attached a screen capture which I think demonstrates the BD navigation performance issue with 2022 for comparison.
I used the continuous logging application from the LabVIEW new-project wizard for testing and tried scrolling the mouse wheel up and down quickly.but in a way which I would expect would scroll quite smoothly.
LV2022Q3 on the left scrolls OK. 2024Q3 on the right is OK with mostly white space but very jerky/slow when scrolling past many nodes/structures.
(1,788 Views)
There's a fix in the latest patch that I believe will address the sluggish IDE problem reported here (Bug 2771439).
If you see this issue in LabVIEW 2024 Q3 Patch 2 or later, please re-report it.
Thanks!
Christina Rogers
(1,637 Views)
