LabVIEW Public Beta Program in 2025
[New Feature] Preserve Values by Default When Placing Diagram Disable Structures
In LabVIEW 2025 Q3, when placing a Diagram Disable Structure to enclose a section of code, LabVIEW will match output tunnels with input tunnels to wire values through in the Enabled frame by default. If LabVIEW is not able to find the source for a refnum or LabVIEW class output tunnel, the tunnel will not be configured with “Use Default if Unwired.”
[Idea submitted by NI Discussion Forums member Jim_Kring.]
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 1 of 1
(799 Views)
