12-05-2025 11:29 AM
With LabVIEW 2025 Q3, we published a Docker image for LabVIEW for Linux.
With LabVIEW 2026 Q1, we are adding support for LabVIEW for Windows. In addition, LabVIEW will have a "headless" mode (i.e., without UI), which it will use in the Docker container.
When LabVIEW is running in "headless" mode, it will not require any license activation. This feature will enable easier setup of CI/CD pipelines.
There is a Beta Docker image (LabVIEW 2026 Q1 Beta for Windows) now available at nationalinstruments/labview - Docker Image.
12-09-2025 01:04 AM
It might be worth considering to add nipkg to env path for this image:
12-09-2025 03:07 AM - edited 12-09-2025 03:13 AM
The same for vipm - it would be nice to have it installed and configured as part of this image
When installed manually VIPM does not work out of the box:
12-11-2025 06:37 PM
The image comes with a "LV26Q1" NIPM feed included that doesn't seem to exist currently
FROM nationalinstruments/labview:2026q1-windows-beta
WORKDIR "/Program Files/National Instruments/NI Package Manager"
RUN ./nipkg update
yields
Step 3/3 : RUN ./nipkg update
---> Running in fcceb6b92d7a
Error -125951: Failed to update one or more feeds:
LV26Q1
and failed build.
Exciting feature, the potential is HUGE.
