LabVIEW Public Beta Program in 2025
[2025 Q3 Feature] Log Unwired Errors
In LabVIEW 2025 Q3, you have the option to record unwired errors in a log file, independent of whether you enable the Automatic Error Handling dialog to report them.
Known Issues
  1. The Explore button is the wrong style and remains “pressed in” after clicking it.
  2. The Log file for current session path doesn’t populate when you first enable Log unwired errors.
  3. The log may contain errors generated by VIs that are part of the LabVIEW IDE.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 1 of 9
(1,392 Views)
Is the functionality also supported in an executable or in PPL (debug version)?
Can the keyword also be entered in the INI file of the exe?
CLA / CTD
Message 2 of 9
(1,292 Views)
All these issues are resolved. Please check the functionality in LabVIEW 2025 Q3 latest build.
Message 3 of 9
(1,107 Views)
Log unwired errors feature is supported in exe and PPL.
Yes, you need to set the token in the exe .ini file
Message 4 of 9
(1,103 Views)
LogUnwiredErrors=True
Christina Rogers
Message 5 of 9
(910 Views)
This seems like a giant security risk. I can open any LabVIEW exe, go modify the ini next to it, then get access to explicitly unwired error messages that may include sensitive data, property information and call chains. I want to be able to indelibly disable this at runtime, since checking the messages of every unwired error in every corner case is not feasible.
This is the guidance I am providing customers in our cyber security Software Development Plan
Unwired Error Leaks New for LabVIEW 2025 In the LabVIEW Options on the Block Diagram tab there is a new option to `Log Unwired Errors`. This option is also available in executables via the ini file next to the built exe. Setting the ini key LogUnwiredErrors=True means unwired errors will be dumped to disk. This is a potential security risk as it could leak internal data and call chains, and it can be modified by end users.
Message 6 of 9
(547 Views)
Accepted by topic author hunter_jki
@hunter_jki wrote:
I want to be able to indelibly disable this at runtime.
Hi Hunter,
You can have your application set the Application property "LogUnwiredErrors" to False to disable logging in the app. This property overrides the INI token.
Do you believe this is sufficient, or do you recommend additional mechanisms to disable the error logging?
Christina
Christina Rogers
Message 7 of 9
(348 Views)
Great news, I will now recommend we always add hardcoded this to false for production hardening. I trust your word for it, but is this priority documented anywhere?
I think this is a simple, and straight forward solution, the nice to have would be a build spec option, so its always set in the same place, as opposed to trying to see if I called this property somewhere.
Message 8 of 9
(199 Views)
I second the request to have it as a build spec option.
Message 9 of 9
(193 Views)
