‎06-07-2016 03:43 AM
I have installed MathScript RT module and I am working on a mathscript node which I want to implement an algorithm.this algorithm contains the Q function which unfortunately don"t exist on labview so I have switched to the erfc function but still don"t work also.Any suggestions please ?
‎06-09-2016 01:57 AM
HI,
I saw that you already posted this question here
and that you should change your function node to C.
Did this solve the problem?
Best,
Anna
‎06-09-2016 03:35 AM
for the erfc function it worked but i need the erfc_inv which it don"t exist besides I have problem also with defining my output.
Do you have any other suggestions please.
Thanks.
‎06-10-2016 04:59 AM
there is indeed no inverse error function in the analysis library list.
But there is a LabVIEW VI: "Inverse Error Function Complement VI" if that helps you.
What problems do you have with defining your output. Could you be more specific please?
Best,
Anna
‎06-13-2016 02:04 AM - edited ‎06-13-2016 02:21 AM
Actually I am not working in labview, I am working in labview communications design.So this VI doesn't appear in my library.
