LabVIEW MathScript RT Module
Mathscript RT module is not working in LabVIEW 2012
Dear Sir,
 Can you tell me where I can download the Mathscript RT module for labview 2012 evaluation version? I've installed Labview 2012 evaluate and try to find Mathscript RT moduel for labview 2012 but I cant. I down Mathscript RT module for 2013 and 2011 but it cant not be installed with labview 2012.
Thank you in advance!
Message 11 of 22
(8,160 Views)
Try this link.
(All NI software is automatically in evaluation version until you activate it.)
Message 12 of 22
(8,155 Views)
Dear Sir,
Thank you for your concern but that link seemly unavailable.
Please recheck it for me.
Thank you so much.
Message 13 of 22
(8,150 Views)
Well, the link works for me and gives the downloader, which, when run, downloads the module.
Maybe access is blocked for certain locations.
Message 14 of 22
(8,147 Views)
Dear Sir,
Could you please... push it in other link like mediafire or something else, that I can download...
I really need it but I cant find other link.
I know that it costs you much precious time but hope you can help me.
Thank you so much.
Message 15 of 22
(8,135 Views)
Did you try to contact NI?
If the link does not work from your location, I won't try to circumvent the security mechanisms in place. Also ask your network administrator if anyrthing is blocked locally at your side.
Message 16 of 22
(8,133 Views)
In order to access older versions of software you will need to have the Standard Service Program (SSP). If you have an ni.com account with an appropriate serial number you should be able to download the software here, http://joule.ni.com/nidu/cds/view/p/id/3176/lang/en . If you don't have SSP currently, you can find the latest version of LabVIEW and several toolkits, including the LabVIEW Mathscript RT Module at this link, https://lumen.ni.com/nicif/us/EVALTLKTSIGPROC/content.xhtml .
The only exception to this would be if you had physical media, a CD, that contained the software you need. I hope this helps.
Miles G.
Emerson Test & Measurement Group
Senior System Support Engineer
Message 17 of 22
(8,120 Views)
I have installed Labview 2012 64-bit on my PC and I need to use Mathscript RT module . But when I want to install this module it shows an error saying " You must install Labview 2012 (32-bit) before intsalling Mathscript RT module". My windows is 7 and 64-bit. How can I solve this problem?
Message 18 of 22
(7,888 Views)
You need to install LabVIEW 32 bit instead. It is fully compatible with windows 64bit. There is no problem.
Message 19 of 22
(7,884 Views)
Thank you so much for your reply. I tried to install labview 2012 32-bit however the installation failed due to the error which says" Contact the application vendor to verify that this is a valid windows installer package"
What does it mean and how can I solve it?
Message 20 of 22
(7,869 Views)
