LabVIEW MathScript RT Module
Import XML und calculate with MathScript
First how can I import my XML file to LabView. And second, how to calculate with the Data from XML with constant number. (e.g. XML Number * constant number = x)
(6,606 Views)
  • Look in the "file i/o...XML" palette.
  • Why does it have to be Mathscript. Scaling with a constant is trivial in plain LabVIEW.
(6,596 Views)
I have no expierence with import XML and reading the XML data. Even some examples I couldn't use it for my problem. I hope that someone can help me.
I need to get every Data from XML and save every number as a local variable in LabView. So that I can work with the numbers.
XML:
<Numbers>
<figure>50</figure>
<figure2>100</figure2>
<figure3>150</figure3>
<figure4>200</figure4>
<figure5>250</figure5>
</Numbers>
(6,585 Views)
